MSI Radeon RX 570 Gaming X 4G Overclocking
We put the power limit to its maximum value of 150 percent before overclocking. With this card, we were not able to change the peak voltage.
Eventually, we reached an overclock of 150MHz, giving us a new boost speed of 1,431MHz – a 12 percent improvement over stock (less than 11 percent if comparing to the built-in OC Mode).
The memory was happy up until an effective speed of 7.6Gbps, which is just under nine percent faster than the default 7Gbps, or seven percent compared to the 7.1Gbps you get in OC Mode.
        Palit GeForce GTX 1070 GameRock Premium Edition 8GB
        AMD Radeon R9 Fury X 4GB
        Asus Radeon RX 580 Strix Gaming Top OC 8GB
        Sapphire Radeon RX 480 Nitro+ OC 8GB
        MSI Radeon RX 570 Gaming X 4GB (OC)
        Gigabyte GeForce GTX 1060 G1 Gaming 6GB
        Sapphire Radeon RX 480 Nitro+ OC 4GB
        Gigabyte GeForce GTX 1060 WindForce OC 3GB
        Sapphire Radeon RX 470 Nitro+ OC 4GB
          5000
          7500
          10000
          12500
          15000
          17500
    Score
Frames Per Second
